I have some connectors that I can't identify. Can you help?
The one in my hand is the oil pressure connector. What is the one that is circled?
These two plugs are after the injectors. Don't know what they are for....
1. Intake air temp? Does it go behind the throttle body?
2. ??
3. ??
4. ??
1. ??
2. ??
These are at the end of the charge cable. Did they go to a fuse box? One has continuity to the positive battery terminal, the other does not. I moved my battery to the trunk. Can I get rid of the battery terminal and the circled connectors?
Ring terminal to starter positive supply?
Knock sensor?
Thanks for helping me straighten these out. I tried searching but all I found were pinouts for the ecu connectors.
I would like to get rid of those that I don't need and clean this up a bit. Because this is going in a RWD car, the intake will be "flipped" so the throttle body is towards the front of the car.
I did order the conversion harness, but they are back ordered. I'm trying to get this done for a car show in April, but I don't know if I can make it or not with the cable delayed.
I appreciate any help you guys can give.
Rob
