1 - 4 of 4 Posts
I’m doing a k20a swap into a ek for my first time was wondering what were the parts I need. I know you need eg LCA and shock forks. What else do I need what tie rods would I need any specific bushing, hard ware ?
96 civic HX K24a
You basically will want to take the entire subframe along with the BOLTS (Most important part as there are different lengths for ek and eg subframe ) from an eg or integra. The outer tie rods are all the same from 92-00 and the inners are as well. If you feel like replacing the lca bushings or compliance bushings while it’s out that would be a good time to do so (energy bushings are cheap ). But when you do the ekk2 setup your front end just becomes an eg/dc from now on.
1 - 4 of 4 Posts
