I'm starting my K20A2 swap into a 93 EG this weekend. I was able to get almost everything including the steering column with the ignition switch and immobolizer, but no key. Is it possible to put in the RSX steering column into the EG. Has anyone tried getting a key cut from Honda to run the stock ECU? Or is it even possible? Is Hondata, EMS, or JDM K20A ECU the only way I'll be able to get my car to start once everything is installed? If using the stock ECU is possible...does anyone have the wiring diagram? Please help...much appreciated.
