1 - 8 of 8 Posts
hi to everyone..i need help..i have a k20a3....which sucks....but im moving up a doing a k20/k24....i want to know...can i use the same harness for the built or do i need to get the original harness....can i use the a3 tb with sensors...or do i need the a2......??????i know the tranny fits....its all on a eg....so let me know plzzzzz
You can use the A3 harness, intake mani, and throttle body. You may need to repin your crank sensor depending on the K24 you are using (see the sticky in this section from Froth). You will need k-pro as well, or AEM EMS, to get it running. Then a tune.
Do you have a header for the K24 yet?
i have the k20a3 on my eg runing so headers and kpro and fuel rail and fuel pre..i have....will the same headers fit...i have dc ones??????so im gonna need to change crankshaft sensor?????
1 - 8 of 8 Posts
