okay.. just to bring everyone up to speed you might want to read up on this here on one of my previous links to know or kinda get an understanding of where i am coming from
http://forums.clubrsx.com/showthread.php?t=258215
okay now with that out of the way let me try and explain the whole scenario from the start...
okay now lets start with the k20a3... heres a quote and a pic from hondata
The VTEC mechanism differ significantly between the K20A2 and A3 head. The K20A3 uses only two cam lobe profiles on the inlet.
the A3 has 2 inlet lobes and no exhaust lobes for vtec... okay with me so far.. no lets take a look at the k20a2
The K20A2 head uses three cams per pair of inlet valves on both the exhaust and inlet.
and heres a better look at the k20a2 cams
okay now here is where the dilemma and why i ask so many questions in the previous forum is to get this out of the blue... i actually have pictures now to help along with the visual aid and so forth... first lets take a look at the motor that i have here
it looks like a typical base k20a3 with the dual runner intake manifold and so forth.. upon closer inspection this is what you see
now if you also take a look on the side of the head it has the same PNA code found everywhere else on the motor
its a k20a that has dual intake runners and a grey valve cover which is kinda strange for it being a k20a... so now lets take a closer look.. someone once told me to look at the oil cap and if it say what oil to put in there.. like 5w-20 then its a us model motor but here is what the oil cap says
Now this is what has me baffled and really puzzled.. look at the lobes of this baby.. it has 3 intake lobes and none on the exhaust
now if you compare to what everyone else says and from what i found..here is a quick rundown
k20a3 has 2 intake cam lobes and 0 exhaust
k20a2 has 3 intake cam lobes and 3 exhaust
the k20 pictured above has 3 intake and 0 exhaust???
so now what does this classify the motor as?? i have been told this was a Euro Type R motor which is the equivilent of the K20a2 which does not look like it to me.. looks like a k20a2.5 or something which falls in between the A2 and the A3.... also the ecu has the code of PRC on the ecu... go figure.. help for anyone that can
