1 - 10 of 10 Posts
Alright before you all jump on me, Cause i know there is someone whos going to say it.. Ive search, Fule cut off, Speed limiter, Govener, Rev limit, look up every word i could think of in using the search tool... anyways so here i goes.
I resently Put A K20A *DC5R* in my 01 Civic. Infact i just got it back to day, and have been noting all the problems that need to be fixed. Mostly small things.. But i was wondering about sometihng. Today as i was leaving A WRX in the dust, my car suddenly lost power at 115 mph then it dropped to 110 and started picking up again, and once again it killed its self at 115. So im figuring this is the govener? or the fuel cut off point on speed.. Is there a way to by pass this? Any help would be appricated. Remember its a TYPE R not TYPE S
iwilson said:
You have the JDM ECU which has a speed limiter build in. You'll need a K-Pro to disable it. Or buy a US ECU (if you do this you'll need to buy the VTEC oil pressure sensor or disable with a resistor or get a K-Pro).
Disable it with a resistor? How do i do that?
It's worth it...
1 - 10 of 10 Posts
