1st off thank you K-tuned(Mike), The guys at Top Flight Motorsports, (Bleek & Ray), And Hybrid-racing. you guys def have all the parts needed on hand and ready to go. you guys both took the time with me on the phone to explain what i needed and how to make it work with the setups i have.. also Thmotorsports.com thanks for the misc. items i needed and for stock parts big thanks to 1320WhtRex, Mr. KDes and Autofair Honda.. if i missed anyone i appoligize..
my name is Rick.. im def. interested in learning all i can!! so any input POSITIVE!!! is def. appreciated..
now onto the BUILD!!
1998 honda civic SEDAN!!
pavo purple engine bay with satin white pearl body..
i am currently working on a k24a2 motor with a K20A2 trans swap into a 98 sedan.. right now the car is in the body shop getting re painted.
the previous owners were running a B series.. after the trans blew it sat for a while..then i bought it... here it is in my driveway. bought just the shell
i decided to gut it just for the hell of it...
and then she left for the body shop...
heres my custom valve cover... wrinkle Pearl black.
sitting next to my daily
the heart k24a2motor/k20a2trans
preping for paint
some rims i bought from a friend
my EP3 seats with custom EK rails
my rear fog light
SI rear conversion
chasebays harness
blackworks headers
CTR headlights
im a carbon feen.. but i PROMISE i wont over due it.. lol Rep. mugen spoiler
what the drivers will see behind me, just a taste
decided to stay with the purple theme and get D2 coils
a clusterf**k of 2 sedan interriors
and then EVERYthing else is behind this all pilled up in boxes, waiting for the release from the body shop
sitting in my garage ready to go to the motor shop
push to start
at the body shop
car all loaded up with goodies!! I HOPE IT DOESENT FALL OUT ON THE HIGHWAY!
just something to beat around on until i get the rims i want
my motor getting assembled
on the way to the motor shop. took it just like this an hour and a half(all backroads, NY to NJ)
at the motor shop
close up of the engine bay paint
heres what i have so far.. everything is uninstalled due to the car at the body shop.
MOTOR:
05 k24a2 motor
02 k20a2 trans
K-pro PRB ecu
Chasebays engine/charge harness
K-tuned package 4
Walbro 255fuel pump
RBC intake mani
Type-s alternator, starter, halfshaft, slave cylinder, shifter box and cables,o2 sensor, throttle body,
Backworks racing header
CRV side mount, gaskets and seals, coolant temp sensor, fan switch
Hybrid racing half rad w/ fan
Apexi worldsport 2 exhaust
Honda firewall plug set
Password jdm tank covers
Hybrid racing test pipe
Hybrid racing shifter bushings
Hybrid racing ground kit
Type-s knock sensor
Type-s IAT sensor
New water pump
fuel pump assembly
Odyssey PC 680 Battery
92-96 prelude relocator kit
RDX injectors 440
K-tuned coil pack cover
K20Z3 cams, camshafts, and rocker assembly
K-Tuned Billet TPS
SUSPENSION:
D2 coils
Beaks tie bar
Passwordjdm 3pt strut brace
ASR subframe brace
Blackworks racing lca's
K-tuned traction bar
99/00 rear brakes
Wilwood front BBK and RECENTLY D2 BBK. (GOING TO SWAP TO THE D2 WHEN I BUY MY OFFICIAL RIMS)
Konig remembers w/ bbs centercaps (picked up off a friend, came with tires. just till i buy something better) JUST PURCHASED MY CCW'S LM5'S
ASR 24mm saw bar with endlinks
Honda Rear break lines
Brake line tuck
Pepboys wheel spacer set
ARP extended lug studs
Hardrace Front and Rear camber kits.
EXTERRIOR:
Roof visor
Window visors
Mugen style C/F spoiler
Yellow housing fogs
Benen tow hooks
EDM rear fog
JDM front parking pole
JDM rear parking pole
Power folding mirrors
50/50 tails
CTR 99/00 headlights
99/00 front end (i have a 98)
AeroCatch Plus Flush Locking Hood Fastener Kit (Carbon Fiber)
Seibon C/F hood
Tein hood struts
PasswordJDM fenderwashers (i keep buying everytime i buy something from passwordJDM)
C/F fog light covers
Seibon C/F Mugen style front lip
Mugen badges for the spoiler
PasswordJDM hood risers
INTERRIOR:
Wink 5 panel mirror
PNP P2S
EP3 front seats
Carbon airbag delete
SI cluster
Mugen pedals
NRG Limited Edition steering wheel
Mugen 6 speed shift knob from 8th gen mugen si
Painted interrior
JDM ITR shift boot
NRG short hub
NRG quick tilt
thats it so far... more to come in the future after the paint shop finishes and i can get my motor in and tune. then ill probably finish up my exterrior and start the interrior work..
TILL MORE COMES!! I WILL UPDATE AS OFFEN AS POSSIBLE!!
MORE PICS THROUGH OUT THE THREAD
preping for paint
my rear fog light
SI rear conversion
chasebays harness
blackworks headers
CTR headlights
push to start
at the body shop
at the motor shop
MOTOR:
05 k24a2 motor
02 k20a2 trans
K-pro PRB ecu
K-tuned package 4
Walbro 255fuel pump
RBC intake mani
Type-s knock sensor
Type-s IAT sensor
New water pump
fuel pump assembly
RDX injectors 440
K-Tuned Billet TPS
SUSPENSION:
D2 coils
Beaks tie bar
ASR subframe brace
99/00 rear brakes
Brake line tuck
EXTERRIOR:
Roof visor
Window visors
Yellow housing fogs
Benen tow hooks
EDM rear fog
50/50 tails
Seibon C/F hood
Tein hood struts
INTERRIOR:
Wink 5 panel mirror
PNP P2S
EP3 front seats
SI cluster
Mugen pedals
Painted interrior
JDM ITR shift boot
NRG short hub
NRG quick tilt
