1 - 20 of 94 Posts
My K20Z2 Engine Building-First Civic FD Auto Type R
Hi guys
Still remember me talking about the which pistons to go? I finally settle down with the RRC pistons with 11.7 compression ratio.
Now I am buidling my engine head and changing the pistons.
For your information, the K20Z2 is the Asia Civic FD2 non Type R engine which is similar to K20A3 engine which has no exhaust VTEC. I am having the Automatic Transmission car and I am building the first AT high cam VTEC conversion.
Now I am changing the head to RBC head with intake and exhaust VTEC and high cam
I will keep on updating the project car. I am aiming for 200whp
Stay tune
Here is my current setup before going for the Type R head and Type R pistons
Engine:
Stock K20Z2
RRC Intake Manifold
RRC Throttle Body
Stock airbox with KNN drop in filter
Removed stock resonator to replace with cold air intake hose
Electronics:
Autogauge 60mm Water Temp
E-Manage Ultimate piggyback system
ECU reflash by me
Suspension/Handling:
G|A|B SS Coilover
Ultra Racing 25mm Front ARB
Ultra Racing 19mm Rear ARB
G|A|B Front Strut Bar
Wheels:
Bridgestone RE050A
Stock OEM Honda 17" 7J 114.3 5 Hole Rims
Exhaust:
Buddyclub Design 4-2-1 Extractor
Custom 2.3" Exhaust Pipe
Greddy Ti Muffler
Discussion Starter #5
Day 1 Progress
Sent my car to my workshop
My engine bay before dropping the engine
My workshop at my city
After taking out the pins of the plastic holder and all the mountings, wirings sockets, exhaust header, my engine is finally down
Engine is took out nicely
Side view of my engine
Front view of my engine
Another view
PNA codded
K20Z2 code by Honda Malaysia
My Euro-R slotted+cross drilled rotors
The engine head code is RBC-3
My mechanics busy doing their work to move the engine to the engine stand
Engine is on floor now before transferring to the engine stand
My Automatic Transmission Gearbox
The Automatic Transmission Torque Converter
Discussion Starter #7
Day 2 Progress (sorry for some poor resolution picture as I am using camera phone to capture, left my camera at office)
Took out the valve cover, here's the K20Z2 cams/valvetrain
Only 1 lobe at the exhaust cam
The economical VTEC with 2 lobe on the intake cam
The cam sensor
Top view of K20Z2 valvetrain
Camshaft took out and here's the rocker arm view
The exhaust rocker arm, i guess it's good for VTEC killer usage
The intake rocker arm
Head took off and now taking out valve springs and valve
Here's the valvetrain of K20Z2
Valve springs and valves took off from the head
Next, port and polish the head (intake and exhaust) for better flow rate
Discussion Starter #8
Day 3 Progress
Took out the block and took out the pistons and conrod
The old pistons and conrods
The crank
Found out one of my conrod bearing is going to wear off soon, so I ordered a new sets of conrod bearing and now waiting for the stocks to arrive
My mechanic busy porting and polishing the head
Discussion Starter #9
Day 4 Progress
The head is soaked into some cleaning chemical to remove the exhaust oxide
It is quite efficient for the chemical to remove it
The intake head after porting, not finalize yet, but the result looks good
Close up
Now they are porting the exhaust part and also touching up the intake port
Stay tune for more updates
Discussion Starter #12
I will still be running on Automatic Transmission
I believe that the gearbox I am having can take up to 300whp without issue. I alraedy installed Hayden ATF cooler so it shouldn't be a problem
This will be a first FD Auto Type R in the world I guess
great work
can you tell me what kind of cleaning chemical to remove the exhaust oxide is brand or what ever
if Jeremy at inline pro made 196whp with just A2 cams alone in an A3 this will be very interesting with aftermarket pistons and different mods. in for results, good luck man!
Im confused though, why in the first pic of your cars engine bay does it say I-VTEC on the manifold cover?
The Professional
are you keeping the header/exhaust setup or are you gonna change it?
Discussion Starter #18
This is an I-VTEC engine. I changed to RRC Intake Manifold and that is the RRC Intake Manifold Cover
1 - 20 of 94 Posts
