21 - 40 of 1353 Posts
RVWerks
Been busy last few days:
Fabricated the fuel cell brackets, drilled and tapped holes to mount it:
Fabricated a cover for the battery box, bondo-ed the rear and sanded/ primed it all:
Received the dry sump tank......genius work of art, internal breather tank, oil filter etc.... simply gorgeous!!:
New heater to replace the oem one that does no longer fit due to the cage.:
RVWerks
went about today mocking up the filler neck assembly. We have molded lexan windows for this car and it seemed cool to mount the filler neck in the rear window. Since this car will also be street legal in The Netherlands, rules dictate that the filler neck should be accessible from the outside....Ran out of fuel hose couplers so took some silicone hose and stainless steel tubing to mock the whole thing up...gives a rough idea of what it will look like, still needs some brackets though and some Hontec tender love & care....:D
why not just go out the rear window instead of the side window?
Nice project...
Nice project...
would be a possibility, bit more complex since the rear hatch/window would also have to open open and behind the licence plate is not bling enough :D.. Bas wanted the opening in the side window, we'll coat the filler pipe white and personally i think it will look great..if only we could fill from the inside and just fill on the cell itself..
Makes sense...
