1 - 20 of 27 Posts
How is the motor holding up? This is the all motor car correct?
this engine is holding up by Innovative Mount 75A(track)
yes,it's a all motor:
K24a1 Abrahm's sleeved
Wiseco Custom Piston 12.0cr-89mm
Blueprint rods
ported&polish k20a2 head,rbc and TB(70mm ported)
BC valve kit+ferrea valves guides
OBX Rh
2.5" very restrictiv catback
K20a2 oem cams
JDM DC5 gearbox with 4.389FD
inside on a very very light EP3(2355lbs without driver and full tank)
Blueprint rods
OBX Rh
K20a2 oem cams
You are using the K20 block with K24 crank right? I would love to see this thing with some nice cams and a better header/exhaust setup.
Discussion Starter · #7 ·
no,this time ended:eek:
i use a K24/K20 franck
yes,i would like to see with better cams and exhaust system!this summer,i'll put a 3" catback:D
Heitzke,our French EP3 weight around 2675lbs with full tank and no driver
JDM KING/K20a Supporter
:up: :up:
Discussion Starter · #19 ·
are you running a front swaybar with the OBX header? if so is it oem? CTR?
nice videos :up:
i plugged off the sway bar!i can't put it on the car with the OBX header even the JDM sway bar we use for the Toda Rh:eek:
about driveability,there's no problem at all!with more 30mkg torque at 2500rpm,you can easily understand:dance:
on road,i use maximum 50% of TPS and i go faster than many cars:silly:
about reliability,no problem to declare about the internal parts like rods,pistons etc...
i've just a recurent prob on a weak on the headgasket but it work fine now
:D
a little test with 2friends of mine:
http://www.youtube.com/watch?v=0CwsnD2IUSk
1st test:inside CTR-T,2nd gear roll 60kmh
2nd test:inside CTR-T,3rd gear roll 80kmh
3rd test:inside CTR K25,3rd gear roll 100kmh
4th test:inside CTR-T,2nd gear roll 60kmh
5th test:inside CTR K25,2nd gear roll 60kmh
spec of CTR-T:
Greddy turbo kit with intercooler 6.5Psi only,RBC,2.5"exhaust,stock internal,5.1FD,E85tune around 300WHP
spec of Evo7:
3" catback,twin disk clutch,20Psi boost,too much ignition advance(knocking hard)...
my car is again on tune because VTC is not tune properly so not really difference between OEM cams Vs K2 cams:eek::wow:
enjoy
1 - 20 of 27 Posts
