I'll probably be out there tomor and open header. I've heard that the omni CMC is good as well. Also my shifter bushings really helped my trans with goin into 3rd and giving the transmission a better feel.
I'll probably be out there tomor and open header. I've heard that the omni CMC is good as well. Also my shifter bushings really helped my trans with goin into 3rd and giving the transmission a better feel.I'll be out there with open headers, slicks, and clean the junk out of my car lol.
Nice!! He gotta have at least head work done to it.Well I ran this same Ep3 you did donsep3, both times from a 40 roll and he got me by 2 cars by end of 4th gear. I don't have video unfortunately because it was a heat up getting to the spot so I took down my GoPro. But he slowly walked out to about 2 cars and it stayed there, so that ep3 is running good, especially for full interior. Ima try to get a rerun.
My car lost too.So this K20a3 EP3 is pulling a bolt on/tuned K20z1 EP3 and a 103 trap RSX? Must be at least FBO (manifold/TB included) a ported head and cams on the a3 if he's still on the 5spd.
He pulled a 370z from a 40 roll too, by 2 cars. I think he has a Z1 or Z3 swap plus headwork. I saw his motor and he has an RBC Mani and fuel rail and he admits to being Kpro tuned. But there is more to his setup. Because he has absolutely NO weight reduction done to the car.My car lost too.
Was the mani cut?He pulled a 370z from a 40 roll too, by 2 cars. I think he has a Z1 or Z3 swap plus headwork. I saw his motor and he has an RBC Mani and fuel rail and he admits to being Kpro tuned. But there is more to his setup. Because he has absolutely NO weight reduction done to the car.
Is this the one i pointed out? if so i bet you the motherfucker is running spray..He pulled a 370z from a 40 roll too, by 2 cars. I think he has a Z1 or Z3 swap plus headwork. I saw his motor and he has an RBC Mani and fuel rail and he admits to being Kpro tuned. But there is more to his setup. Because he has absolutely NO weight reduction done to the car.
Nah it's not cut.Was the mani cut?
I've heard of him running spray in the past from other ppl too. But when he showed me the motor I didn't see any lines or anything, plus he only pulled 2 cars on me. Hes probably all motor.Is this the one i pointed out? if so i bet you the motherfucker is running spray..
hmm. when the cams go in ill see what i can knock out... lolI've heard of him running spray in the past from other ppl too. But when he showed me the motor I didn't see any lines or anything, plus he only pulled 2 cars on me. Hes probably all motor.
Yeah I'm curious too! That's little Ep3 moves tho. After you do cams you should run him, probably be a good run.hmm. when the cams go in ill see what i can knock out... lol
Yeah, we will see.Yeah I'm curious too! That's little Ep3 moves tho. After you do cams you should run him, probably be a good run.
Yes 370 had a passenger (donsep3) but he is a light guy. The 370 has intakes and I believe exhaust and maybe test pipes, it runs good tho. Either way you look at it that 370 is probably a 105+ car with a passenger and those mods at the very least. And that ep3 pulled 2 cars on him up till about 110. The ep3 is a solid high 12 sec car in my opinion.Didn't the 370 have a passenger though? I've pulled 2 370s, and have had 2 pull me. Never ran one on my current setup though. I'm sure I'd be even or maybe pull a stock one, but not a modded one. I need a tune first.
I second that!make a trip down here and and well grab a few beers.
