721 - 728 of 728 Posts
I am ordering a few of these S2000 filters to go into my set. I am going to use the Honda (Fram) oil filter for a 75 miles service, then train. The next on will the Honda (Fram) oil filter being run with copper gasket fixers and run it for 200 miles. Finally, I will switch to the JDM Honda HAMP oil filters with AMSOIL. . I new to order the S2000 oil filters for back up filters.
97 civic HX K24a
Discussion Starter · #726 ·
Are you doing a new shortblock or just want to flush out any nonsense from it sitting ? Either way sounds like a thorough procedure. I idled the k24 a few times then did an initial oil change , after about 150-200 miles did another one and now I’m almost at 400 miles on it. At 500 I will probably do one more flush with the supertech oil and oem filter. I have looked up testing done of this Walmart synthetic oil against the big dogs and it performed very well, not to mention for half the price 😅
97 civic HX K24a
Discussion Starter · #727 · (Edited)
I had some time this morning to change my starter out , I have been experiencing intermittent non start issues with just the solenoid clicking and after several voltage tests coming back good over the last week I concluded its not the battery, but the starter that was my issue.
Bumper off for easy access
Tire Wheel Automotive parking light Vehicle Automotive lighting
Car Vehicle Automotive lighting Automotive tire Hood
old one out, flywheel looks good 👍
Tire Wheel Automotive tire Motor vehicle Crankset
Unknown denso auto starter I purchased ($20)from a friend initially for the swap alongside the used auto CRV starter from LKQ(53$) (I like buying from these guys because all the parts are tested ) the two pieces look pretty different but everything works the same. ALL USDM k20/24 starters are compatible , the Jdm models do not work !
Tool Gas Machine Metalworking hand tool Slip joint pliers
All done !
Motor vehicle Automotive fuel system Black Automotive air manifold Gas
not only is my cranking sounding better but there is no delay between the key turning and the starter engaging, before there would be a slight hesitation upon key on before the car would crank, if it would at all. I feel much better about taking the car out now 😎
