is it for the street!!!!
Yes sir!!!.... Occasionally...... It won't be my daily driver but it could be.....trying to stay more track to avoid law enforcement problems......ef89wantsk20 said:is it for the street!!!!
Not sure of the exact size of it. I know the name is Gatorback from Goodyear. I will post the part number when I get home.. Project as for now is going really slow... I started school and am going Full time plus working 40 hrs a week..honda_b_blastn said:Did you run with the 31inch belt? or did you need to get a larger one to suit the washer/pulley setup?
1320WhtRex said:Not sure of the exact size of it. I know the name is Gatorback. I will post the part number when I get home.. Project as for now is going really slow... I started school and am going Full time plus working 40 hrs a week..Starting to get depressing.. Im waiting on my Manifold, DP and Dumptube [email protected] so I can at least get it out of here for piping...Oh well.
Actually you dont even need the pedal assembly... You can use the pedal that you have now and reverse mount the Slave Cylinder on the inside, using the hook from the cable setup to push the CMC.... I may be working on it this weekend.. If so, ill definitely post pics....Nuckingfuts said:hey, i plan on running a hydrolic clutch pedal set-up also:up: i got a pedal assembly out of a 95 civic si (from a friend) and also a master cylinder from a 95civic si. i plan on running the hardline through the framerail thats about the only "wire tucking" i plan on doing. no ugly clutch cable resting on the valve cover and i love the pedal feel of hydro![]()
I used a longer Gatorback Belt from a local auto parts store around here (Autozone). The part number is 4060390 6PK990...honda_b_blastn said:Did you run with the 31inch belt? or did you need to get a larger one to suit the washer/pulley setup?
Thanks man... Nope.... Cant get the Kpro without the ECU... Waiting on it from Nikos... Its in his accord that he cant find the keys for...signalpuke said:Word! Looking good man. Cant wait to see this mofo...i keep reading about how stout the blocks are, boost is sounding better and better.
You get that Kpro yet?
On the street....10....15..lbs.....Droppedcrxsi said:Inj size is based on HP, what kinda boost ru looking to run??...
Well I am using the old washer hole for the piping form the Turbo..... Its the piping from the TB that im concerned about.... Might have to make that hole like you guys are doing in that gunmetal CRX but on the other side......Droppedcrxsi said:.....Yes, use the hole for the old washer location if you can.
Yeah... Me too.. I asked him about it and he couldnt really give me a specific price... I felt like I was getting the runaround.. All he was saying that it could be done, which I already knew that.signalpuke said:I wish the TB was on the otherside:silly:
Maybe Jeff can fab that up if there is enough interest...I am sending my mani to him to have it ported, might be a good for the turbo setup too. I wish we had more damn room in the bay
