1 - 15 of 15 Posts
This is a aftermarket engine harness that bought from off eBay. I know the color doesn’t match but I want to know if all the pin is in right place
That why I’m asking if the pin are in the right place. Whoever made the harness might have put them in the wrong place. That why my alternator isn’t getting charge
My engine harness isn’t Acura rsx type s oem so the wire color is all different from the pic you sent
If the harness is a tuck harness to replace a stock RSX harness then the pinouts would be the same on the ECU side. Find out what cavity on the ECU side your alternator wires run to. So, you would use a meter to verify continuity from B10 to pin 3 at the alternator, B13 to pin 4, and B18 to pin 2. Wire color doesn't matter at that point.
If your tuck harness isn't for an RSX then tell us what it's for as the pinouts might be different.
1 - 15 of 15 Posts
