1 - 2 of 2 Posts
Get all of your fluids from us.
Street
8100 5w30 Eco-nergy
-recommended NA or Turbo builds.
-make more HP
-Better MPG's
-Uses PAO base stock or Group IV base oils for better protection
-API SJ - more extreme pressure additives in the oils for race use
8100 5w40 X-cess
-Used in high boost situations
-Utilize larger molecule for more protection (Aka HTHS high)
Race & high class street
300V 5w30 "Power Racing"
300V 5w40 "Power"
-All 300v engine oils utilize double ester technology - 1 ester for lubrication - the other for extreme pressure
-Molecular bond - ester molecules are polar meaning magnetically charged to metal surfaces (great for lubrication or no drip down effect at start up) less wear
-Make more HP / Torque
-Stable oil pressure
-Will not break down (when you drain the oil, it doesn't used or watery like some synthetic oils
Transmission
MotylGear 10w40
- Ester reinforce gear oil for noisy or hard to shift Honda transmissions
- good for use with helical style limited slips
90PA Lsd (12 - 2 L - bottles per case)
- used for clutch style limited slip applications
Brakes
Dot 5.1 - 523 boiling pt for street driving
RBF600 - 594 boiling pt for racing
RBF660 - 617 boiling pt for racing (non upgraded brake systems generating more heat)
Coolant
MoCool radiator additive
-Mixable with water or coolant to reduce engine cooling temps by 30 degrees
-Not harmful to cooling system because its non soap based, does not leave white residue like other radiator additives
-Track non slick approved for race and track cars
Inugel Expert Ultra
-Mixable coolant 3:1 ratio
-Contains some MoCool additives to reduce engine temperatures
Additives
Engine Clean
-Pre oil drain additive to increase synthetic oil life
-Motul's additive package actually will clean old impurities in the engine if previous coking deposits do exist
Specialty oils
-API SG - 1980's rating that contains zinc, phosphorus, Sulfur - these additives are extremely good for break in.
PM or Email me for special K20A.org pricing.
HybridRacing.com
[email protected]
-David
1 - 2 of 2 Posts
