Hi all, long time reader first time poster here. I'm in the process of building an Opel GT endurance race car and wanted to run a few questions past the community to get some good opinions or information.
The main parameters of my build requirements are that the motor must be built with OEM parts (except injectors, pistons, connecting rods, and crank) and also must be N/A. The OEM parts can however be modified (ex. ported heads)
The goal is to make between 240 and 280 crank HP
But onto the questions:
1: What would the ideal OEM parts K series motor be? a K24a2 lower with a ported k20 head? a ported TSX head? What about intake and exhaust manifolds? Basically if you could mix and match all the OEM K series stuff what would you frankenstein together for reliability and power?
2: I'm planning to modify my oil system by adding an Accusump system, an external cooler, and by adding baffles to my OEM oil pan. Is there anything else I can do to improve the oil system, especially with constant G forces?
3: Does anyone know of any similar builds or posts they could link me to? I'd love to get as much information as possible!
Thanks in advance, your input is much appreciated!
