I just thought this was interesting, so I'll share with everyone...
http://www.honda-tech.com/zerothread?id=984808
exactly why i don't want to use washers. just think what would happen if i hit a fat bump on the freeway and that bolt broke. I also feel its more likely to break since im running 1000lb springs in the back.K2e2vin said:since the bushings dont fit in snuggly, wouldnt that cause more stress on the bolt? and also if you use washers as a fix, wouldnt it still cause stress because none of the load is transfered to the washers.
If you had the correct size washers I don't think you would have anything to worry about? :roll:909edge said:exactly why i don't want to use washers. just think what would happen if i hit a fat bump on the freeway and that bolt broke. I also feel its more likely to break since im running 1000lb springs in the back.K2e2vin said:since the bushings dont fit in snuggly, wouldnt that cause more stress on the bolt? and also if you use washers as a fix, wouldnt it still cause stress because none of the load is transfered to the washers.
still no energy will be transefered through the washers. washers are only for spacing, so all the load will still be put on the bolt. the best setup is to have the ends as close as possible to the shocks.jon v said:If you had the correct size washers I don't think you would have anything to worry about? :roll:909edge said:exactly why i don't want to use washers. just think what would happen if i hit a fat bump on the freeway and that bolt broke. I also feel its more likely to break since im running 1000lb springs in the back.K2e2vin said:since the bushings dont fit in snuggly, wouldnt that cause more stress on the bolt? and also if you use washers as a fix, wouldnt it still cause stress because none of the load is transfered to the washers.
yea they should. from what ive read, EF, EG, and DC rear LCAs are all the same.Dc5itracer said:Will any of this stuff fit an ef and if it dont what would i need to change so i can make them fit the ef![]()
those are the function 7 pieces they are super nice and what I should have bought in the first place...K2e2vin said:these look nice:![]()
