1 - 3 of 3 Posts
There is a slight difference between auto and manual.The auto has a few more plugs at the transmission for auto tranny solenoids,and no reverse lockout solenoid.
The auto also uses two extra ecu plugs.... "c" and "d" plugs.
You can use auto harness or base model manual harness to wire up the A or A2 engines with a little modification.
1 - 3 of 3 Posts
