Ok guys just got my NA K20Z1 build together on my 06 type s. I've dropped endless amounts of money into this motor and am now highly disappointed in the numbers the car has put down. Car put down 210WHP/131TQ on a mustang dyno. Those are numbers people are hitting with just bolt ons and a tune so something is up with this motor/tune. I sent the block out to get sleeved so when I eventually do my supercharged aftercooled setup I didn't have to break it down again. I'm leaning towards the ring end gaps being set for a boosted application and the valve lash being a little tight is where I may have lost power. The ring end gaps are .019 top, .023 second ring, .015 oil rings. Valve lash was set to .30mm COLD, I know Kelford calls for .30mm hot but until I solve this power issue I'm not getting my hopes up in gaining 30WHP+ strictly on the valve lash, maybe an extra 10whp max from redoing lash. Anyways the mods are:
4 Piston Racing Pro 156 ported head
Kelford 179-B2 cams, exhaust degreed in to 103 BTDC
Supertech Valves, Supertech 92psi springs
Ported RRC Manifold , ported matched runners to head, TB inlet Ported to 70mm
Blox 70mm Throttle body
Deatschewerks 600cc injectors
Club RSX/Private label Race header
Injen Cold Air Intake
CP Pistons 11.5:1 Pistons
Manley H Beam rods
Darton MID sleeves 86mm
K-Tuned 3 inch Oval exhaust
Please save the smart ass comments/criticism to yourself, I have been a Subaru/Hyundai tech for years so I have more than enough experience. From numbers I've seen regardless of dyno manufacturer this setup should easily be good for 260WHP. So my question is, where am I losing the power? Ive compression and leak down tested and my numbers are 170psi on cyl. 1&3 and 160psi on 2&4. On wet compression test the comp numbers jump to 205-215. I would say the rings are shot but I am not burning oil at all and this thing sees 8800 RPM daily. Also on a leakdown test I am getting 0% leakage on all cylinders with the motor hot, and this was done on a separate day from the wet compression test, that way there was no oil in the cylinder to throw off the results. No oil in the cylinder when I take the plugs out and plugs are dry mocha brown colored. So what experienced engine builder has some good insight for me? I was thinking of adjusting lash and seeing if it changed the dry compression significantly. Car has been E-tuned by one of the most reputable tuners on the east coast, who also suggested possibly valve lash having to do with it. Anyone with some good knowledge and insight feel free to chime in.
Manley H Beam rods
