Here is a link to pics since i am having a hard time uploading them
pics.pics.pics.pics.pics.
http://sandiego.craigslist.org/csd/pts/960946671.html
99 b16 head complete sold
CTR cams sold
skunk2 gen 1 cam gears sold
stock b-series cam gears $40
OG spoon header $200 pending
Spoon muffler(axle back) $250 or $300 with silencer pending
black 94 si door panels 1 has a 2inch slit and the other is missing the window weather molding strip $80
have 1 eg black carpet and just the carpet has a softball size hole in the passenger rear side $80
1 eg hatch grey carpet with the door sills still attached no holes pretty clean. $100
bseries speed sensors $40 each
1 set of 95 gsr cams $50
1 Gsr crank nothing wrong with it $150
1 LS crank nothing wrong with it $150
95 obd1 civic ex harness$100
94 obd1 ex harness moded for gsr/b16 swap $100.......... sold
2 obd2a 96-98 ex civic engine harnesses moded for gsr/b16 motors $100 each sold 1 have 1 left.........pending
94-00 integra black steering wheel airbag $60
92-95 civic hatch/coupe drivers side window $40.....sold
2 92-00 civic radiator fans $30 each
1 gsr bare block w/caps $200
1 gsr bare block cracked sleeve with caps $100
1 b16a bare block with caps includes crank but has messed up journals $100
1 bare ls block with caps $100
92-95 civic hatch/coupe blue dashboard painted black includes underdash harness $100.........pending
92-95 black rear hatchback cargo cover $70....................sold to ieatrice
92-95 a set of black interior rear quarter panels $130
92-95 a set of grey interior rear quarter panels $100
92-95 civic hatchback rear black trunk lid $40 each
1 set of 95 gsr black door panels $100
2 p2 obd2a ecu's $60 each
1 set of 92-95 civic hatch/coupe usdm headlights $60
1 set of usdm 99 type r rods with pistons $150
1 set of usdm b16 rods and pistons $100
1 set of gsr/b16 cam caps $40
set of 4 dunlop sp sport01 3000 195/55/16 tires lots of tread left $200 don't low ball each tire is $200 new
set of 4 hoosier r6 205/45/16 had one pass at willow springs $350 these are real expensive tires.........pending
set of 99 usdm front ITR seats and jdm rear ITR seats without the plastic and carpet for the rear seats for an eg 92-95 hatch $800 or $700 and your stock seats
CRX autopower rollcage $300 or trade for an EG hatch autopower rollcage
96-00 civic coupe 2 1/4 inch piping with b-seies motor and generic muffler $100
96-00 civic hatch back buddy club piping from header to muffler with b-series swap $100
99 ITR piping with obd1 cat hallowed out will also fit 92-95 civic hatchbacks $120
1 set of generic coilovers for 88-00 civic 90-00 integras $100
2 generic coilovers for 88-00 civics and 90-00 integras $50
obd1 b-series alternator $50
obd2a b-series alternator $50
GSR obd1 distributor $120
performance lightened flywheel, 4 puck sprung clutch and pressure plate might nee new clutch $200
95jdm gsr tranny has a rattle and grinds on top of third have the bearing to replace the rattle $250
JDM b16 intake manifold $40
USDM b16 intake manifold $40..........sold
JDM Gsr intake manifold $40
shortshifter $50
USDM type r shift knob $40
2 b-series shift linkages $50 each
2 beseries half-shafts male on tranny side female on drivers side $40 each
LS oil pan $30
GSr oil pan tapped for turbo $60......pending
92-95 civic ex coupe trunk carpet that attaches to the back part of the rear seats $40
92-95 civic usdm black cup-holder $25
92-95 civic black usdm center console $25
92-95 black usdm e-brake cover $25
92-95 artic white coupe trunk has holes for the spoiler $50
92-95 civic si complete hub and caliper for passenger side need new wheel bearing $60
92-95 civic ex complete hub with caliper $75
obd1 p28 ecu auto and virgin $70.....pending
2000 gsr long block does not have engine harness, ecu or tranny. comes with a skunk2 intake manifold and type r throttle body.it is legit i helped pull it from the wrecked integra. $1000 picked up.
might even have other parts just ask.
everything is best offer.
parts I need are
JDM type r front recaro seats black with red stitching
EG 92-95 hatchback autopower roll cage
k-series parts for an eg
k24 block
92-95 civic hatchback traction bars
miracle x bar
k-pro
rota 15inch slipstreams
work euip03 15inch knock off wheels or dr20 wheels
let me know what you have to hook up my 92-95 eg hatch.
e-mail
[email protected]
or call me at or text at
760-215-0933
i never pick up numbers i don'k know so please just leave a detailed message if i don't pick up. I will call you back as soom as possible.
CTR cams sold
shortshifter $50
LS oil pan $30
parts I need are
k24 block
miracle x bar
k-pro
[email protected]
760-215-0933
