1 - 6 of 6 Posts
Looking for a Gasket to lower my Compression.
11:5:1 is my compression on my K20A. and Im Boosted. Im running at 6PSI.
I want at least 8 or so, I plan on upgrading the Pulley and Injectors and with my compression low I can get more HP :)
Please HELP!!
Please HELP!!
sorry by using the 2mm metal gasket you can gain only 2point lower compression as i said from 11.5 to aroung 9.8 or something. My self using a 9:8:1 Piston Lower down to 8:5:1 Compression or you can change to normal rsx piston that only 9:8:1 compression
The metal gasket you can get a new only and go laser cut ....
Thanks man Where do I get that??
and you said It'll lower my compression from 11:5 to 9:8????
Please HELP!!
You make more HP per a pound of boost with higher compression... So I don't know why you said "with my compression low I can get more HP :)".
Just leave it where it is and spend a few extra hundred getting it tuned really good.
Thats what i would do... :dance:
NO that is not ture no one makes it...and it's just not worth all the work just for .2point...
that means all you are going to get it 11:3.1 :down:
What jon v said, get it tuned right and you are done..
1 - 6 of 6 Posts
