1 - 7 of 7 Posts
ok i have a jrsc-s and until yesterday night it was fine, i first started getting suspicious when i could hardly beat a 00 si, but then again tonight my car felt REAL sluggish, i mean like stock, and it sounded funny sucking in air, and there was an odd tone to the exhaust, then i look at my boost guage, its all most in vaccum the whole time, so i WOT, and it wont pass 2psi, where normally its at 5, 5.5. what can be the problem? belts and hoses seem to be fine.
ok first off do you have k-pro? if not i take it you have a reflash, if your not throwing any check engine codes then start w/basics like i guess you did check belt have a buddy hit the gas while your parked and look at the belt then make sure like you did all the hoses arent leaking anywhere then make sure all bolts for supercharger are tight on mine one of the bolts fell out that mount under the jrsc. If none of that solves your problems then contact jackson racing tech support, If you have more details then let me know GOOD LUCK.
time to check the compression...
1 - 7 of 7 Posts
