41 - 60 of 66 Posts
updated post (but not updated since signalpuke quoted me :p )
Joe, I posted pics of the maxi-lite spec cards with & without the upgraded bolts. It appears pin end diameters are different on the card, lol I think it may be a misprint on my card as a .8660" WPC treated CP wrist-pin fits fine
FYI here is what can happen when you combine mis-shift + long stroke + lightweight (china) rod = stretched arp bolt & kaboom
Was this your rod??? What brand of rod was this and was it a turbo or n/a set up?
Anyone has any experience with BC lightweight Sportsman rods? Part #BC6052
I don't plan to rev to the moon. I want my k24a2 to make it's peak hp around 7800-7900 and have a max of 8400 rev limit. I am just trying to take some weight from rotating assembly as much as I can and not spend 1-1.5k on a set of rods. I'm already going with a2 oil pump, type-r flywheel etc. Might as well change rods and have ARP rod bolts for more safety.
Thanks
ALL 4 bangers are hard on rod bolts , thats why offy/ drake used 1/2 bolts on 1000 hp turbo engines in 1960. i even have seen a rod they made with 4 rod bolts @ 7/16 .. ubber bolted.. imagine 4 bolts on the big end!!
some bc rods offer 7/16 bolts as a standard part # now, the others , crower , cunniham have to make them ( 12-20 weeks ) ..
someone i know started the 7/16 bolt thing on my esslingers in about 99'. the fat bolt can be less costly and provide more clamp psi than any 3/8 or 8 mm does.
btw - pankl titaniums are 330 grams @ 6.125" ctc ( add to the list ) 1770$ each rod.
WOW, $1770 for each rod? too rich for my blood!!! Those are money racing rods!!!
Saenz custom 300m steel rods w/ 9mm ams5844 bolts (H-beam), for K20:
C-C: 144.2 mm
PE bore: 19 mm
PE width: 21.5 mm
BE bore: 51 mm
BE width: 20 mm
Total mass: 405 g (BE 303 g, PE 102 g)
Note: longer C-C, max RPM 10k, max WHP 450 (total), no PE bushing, and given piston/pin mass of 350 g.
Application is street with some racing. light boost. Oh, and cost is very reasonable, much better than Ti.
Makes you wonder what 330 grams of raw Titanium cost or the scrap value of a bent rod!!! lol... :)
Raw titanium or used alloy isn't terribly expensive. A lot of the cost comes from making the proper alloy with very low impurities and defects, not to mention the forging and/or machining. From here, the cost is nearly $10/lb of raw Ti6Al4V, but good quality material would be further processed.
Here's a nice overview:
http://www.roymech.co.uk/Useful_Tables/Matter/Costs.html
Thats pretty cool, Thanks for that info, it seems the price has actually come down significantly in the last 10 years or so, with a majority of the cost coming from the manufacturing, rather than the metal itself! With the price of gold and silver skyrocketing, you would think it might follow suit, but I guess it's a far cry from actually being a "precious" metal!!
:new_slayer:
Lets keep this thread going:up:
When using eagle, scat or manley H beam rods, has anyone used the custom aged 625+ rod bolts with them? They're rated at around 265,000-280,000 psi IIRC, unlike the arp 2000 rod bolts which are around 220,000 psi.
I'm trying to decide on a set of rods to use, last part of the build, K24/K20. This is a true DD car with 09 TSX pistons, dc 2.2 cams, I/H/E and KPRO.
I think BC lightweight Sportsman rods #BC6052 could be a good choice ;)
Been There Done That
good thread. i too am looking for rods for a future k24 build trying to hit 300whp revving to 9k. true daily driven street car.
so far my choices are carillo pro A and crower maxi-lite
Good choices. I was also looking at the carillo Pro A but I'll be using stock pistons and def not looking for that much power. Was talking to Luke (Drag) and he recommended the Manley H-beam rod if you wanna do a budget rod :up:
41 - 60 of 66 Posts
