1 - 20 of 49 Posts
Well, I'm getting ready to start my K24-RX build and as much as I wanna go fast I would like to stop fast. And 20 year old brakes just aren't gonna do the trick!
My question is what options do I have? From top of the line to Low budget big brake set ups.
Whats out there, and what are you guys using?
Discussion Starter · #2 ·
C'mon everyone is drivin around there with stock brakes?
This could make for a good topic that isnt In the EF FAQ section? And id also like to know personally.
Search button can be your best friend. Mine is simple and should be effective. Will know when finished. But just by the feel of the pedal it feels good.
91 SI front brakes with slotted rotors
93 DA Rear disc brakes
Slotted Brembo rotors in the front and rear
DA Brake master cylinder
Custom mix of hardline-stainless braided lines
My brake pedal is firm as hell and only moves like an inch. Almost feels like if I wiggle my toes the car will slow down. LOL
I used:
DA brakes all around.
Stainless lines.
EBC Green Stuff pads.
91 Civic EX 15/16 Master Cylinder.
Worked well for me, tires were only 205s.
I used:
siR Knuckles
Hel Braided Lines
Da 40/40 Prop valve
1" ITR Master Cylinder
EBC Red Stuff Pads
Spoon Calipers
MG ZS rear Calipers
MG front 282mm Discs
MG rear 262mm Discs
Discussion Starter · #7 ·
Thanks guys, I know there's info out there just havnt seen much here in the EF section.
Dan_ef8 are those rotors available in the US that you know of?
And keep em comin guys!
Discussion Starter · #9 ·
Running DA brakes on an EF, does it require changing the whole spindle over?
I know you have to do that when putting 99 Si brakes on an EG
you can use da knuckles get prelude 11.1 rotors have them redrilled to 4x100 and use type r calipers for 11in you would want to up grade you master with this and have to use 15in wheel
i have itr 5 lug with 11in front 10in in back with 1in master and da valve fast brake slotted rotors and ebc pads stops good
Discussion Starter · #14 ·
What year/model prelude would those rotors come off of?
Discussion Starter · #17 ·
Thinking about going ahead with Wilwood Front brake conversion, an DA integra rear discs.
Wilwoods front brake conversion for a CRX is about $650.00. By the time you buy DA front knuckles and some nice brake pads to match youre over half of that.
I used:
Stainless lines.
x2.... Works well for me too.... :up::up::up:
I have 90 da brakes all around with 91 crx si p valve and 88 prelude master cylinder. I just bought 4 pistion Wilwood kit with 11' rotor for the front.
1 - 20 of 49 Posts
