my car seems to be leaking oil from where the head meets the block.
does anyone know what this could be?
i just recently went to a K24 oil pan, could the shop that did the work have overfilled it with oil by accident?
my oil pressure at idle is around 24 psi, crusing at 3000 rpm it is around 85-90. the dipstick level is full, even a little over the full mark. the dipstick should still read correctly because i'm on the k20 block, right? even with the 24 pan.
it's also been losing a little bit of oil pressure when i put the clutch in or come to a stop. it'll drop to 15 or so then jump back up to 24.
the oil is eneos 5w30.
here are pics:
here are pics:
