1 - 4 of 4 Posts
Has anyone used the ktuned coolant bypass with a JRSC on a K20z3? I want to rid my setup of the Hasport adapter plate and use a bypass instead.
Thanks, Ed
Something you can do is tap the two holes to right of the intake port. The small one taps out to 3/8npt the large one 1/2npt. The 3/8 npt gets plugged and 1/2npt gets a 90 degree 5/8th barb. This does require drilling a hole in the back of the head as you are using the EGR port (the large hole) as the coolant bypass.
This what I did on my RWD turbo k24a2 same coolant setup in the head as the k20z3
Sent from my SM-G960U using Tapatalk
Discussion Starter #4
For future reference, it will fit according to Ktuned. Another alternative is Tractuff. I ended up going with the Tractuff adapter.
1 - 4 of 4 Posts
