41 - 46 of 46 Posts
Lol months later. So which radiator are you going to use now?
My choice would be Koyo
CSF claims to utilize OEM Fan, it shows it have provision for the mounting on their diagram
one received is blank
Also, CSF only have provision for fan switch and not coolant temp.
What modifications have to be made to get the K swap CSF into an EG civic?
I have this rad in my eg (prototype of the version 2).
The v3 version of this rad is pretty nifty. It comes with upper and lower tank interchangeable AN and hose barb fittings, accommodates the factory EG upper radiator bracket location, and the lower mounting pegs accomodate both EG and DC2 mounting spots. can see it on their site:
http://csfrace.com/ultimate-k-swap-radiator-v3/
It basically drops into either an EG or DC2 chassis and the upper neck is in the correct location for RBC/RRC manifold use.
If you're not comfortable with the EG upper rad bracket, you can get some ASR upper rad brackets that will utilize the upper integra mounting pegs.
The filler neck has 3 positions you can set the reservoir hose barb to (to the left, towards the manifold (y tho), and to the right)
The csf radiator
you can mount stock cooling fans to it correct? Ep3 can you mount stock dc2 cooling fans to it? I would think not?
im using a 02-05 civic si (ep3) koyo radiator in my dc2. running for 2 years no problems at all. no modifications to the lower radiator tabs and using upper oem brackets.
Question what did you use for the cooling fans for this setup? Looking for cost effective solution. Swapping jdm k20a from a dc5 into a dc4
41 - 46 of 46 Posts
