1 - 4 of 4 Posts
hey guys like the title says I'm having trouble with the vtc malfuncion error code, just wanted to make sure if there is a fix for this issue. Here's the thing Irecently bought a Kpro secondhand, the thing is he had a 05 rsx, mine is a 03 so since i installed the Ecu my car has been showing up the check engine with the vrc malfunction, the dataligging on the ecu says that the cam isnt moving. and when the chek engine is on car doesnt activate vtec, speedo is working fine. Also with the stock ecu car works fine with no cel so i know the vtc sensor for the 05 rsx is diferent also the speed sensor, just wanted to make sure if there is a fix other than sending the ecu to hondata to reprogram it?
yeah I kind of learned that the hard way, just wanted to make sure if there is a fix other than sending it to hondata to reprogram it
There is nothing Hondata can do about this. You should either get your money back, or sell this along with the harness to someone with an 05/06 RSX. Then you can purchase a K-Pro for your original ECU.
1 - 4 of 4 Posts
