Any and all help is appreciated 🙌🏻
Problem: I keep getting code 34-2 "vbu high voltage" code on kprov3
Car: 97 civic ex with a k24a2 and 5speed swapped, the car has a ry-wire engine harness and conversion harness installed (pics attached), k pro v3 on a PNF-A03 ecu
Items newly replaced: starter, alternator, main relay (checked 3 from pick part), I added extra grounds so I have about 6 now
At this point Im lost 🤷🏻♂️, I'm starting to think its my ecu or kpro? because the engine harness and conversion harness should be pnp, I don't know what else it could be? Thank you for any help!
