1 - 12 of 12 Posts
I don't have a data link connector on my rcrew harness. So if I get kpro, can I check why my check engine light is on through kpro? And I also gotta check why my ABS light is on.
I don't know about the ABS...but the check engine light you can...and it will tell you what's wrong...
GoldStar
typer0186 said:
I need my ABS, I love it. If I didn't need the ABS, I would of taken the hole unit out to save weight.
it could be anything from the sensors to low fluid.
Discussion Starter · #9 ·
The ring is on there. The only thing I did at the time of the swap was unplug the abs pump and plugged it back in thats all. I'll check the brake level tomorrow.
1 - 12 of 12 Posts
