1 - 7 of 7 Posts
I have an EM with koni 4-ways and I keep having a problem with the two rear struts.
If you are unfamiliar with this set up (EM), there are two recessed grooves in the bottom of an EM Koni strut. A metal clip is placed inside either groove, depending on with ride height you want, which holds up the spring just under the spring seat.
I have had the clips on both settings, but they keep breaking. Any suggestions?
Yea. They replace the clips but eventually they will break again. I tried putting a hose clamp underneath the clamps this time. I know that's a ******* ass way to fix something, but I'm tired of dealing with it.
Thank you though.
Discussion Starter · #7 ·
I have Eibach Sportline springs. They are only a 1.8 in. drop. Oh yea, when I have stock bump stops in, my struts ride on the bump stops. So I cut them in half today, and everything seems fine. I guess I'll find out when I make a 600 mile drive home sunday.
1 - 7 of 7 Posts
