1 - 20 of 216 Posts
Karcepts, Inc. is proud to offer the SOLUTION to directly bolting up an 02-06 RSX-S/ITR or 02-05 Civic Si/CTR Throttle Body to an Accord Euro R, 06-07 Civic Si, or 04-05 TSX Intake Manifold.
Ease of fitment has been confirmed for the following vehicle/engine/mount combinations:
· 1992-1995 Honda Civics equipped with a K20 engine and Hasport EGK1 mounts
· 1996-2000 Honda Civics equipped with a K20/24 engine and Hasport EKK2 mounts
· 1994-2001 Acura Integras equipped with a K20 engine and Hasport EGK1 mounts
· 2002-2006 Acura RSX-S/Honda ITRs with a K20 engine and all available mounts
Note: If attempting to install a throttle body and intake manifold into a vehicle/engine/mount combination not currently confirmed, modifications to your chassis may be extensive.
What you get:
Provided plug for unused MAP sensor port:
EG fitment:
02-04 RSX-S fitment:
05-06 RSX-S fitment:
Always in stock:
PRICE IS $60 SHIPPED DOMESTICALLY!
Buy online here: http://www.karcepts.com/index_files/products.htm
Details located here: http://www.karcepts.com/index_files/KIMRBCA.htm
K20A.org development thread here: http://www.k20a.org/forum/showthread.php?t=9761
View the Installation Instructions
Any questions? Just let me know...
Thanks,
Brian Karwan
Karcepts, Inc.
www.karcepts.com
[email protected]
Re: Karcepts K20/A2 Throttle Body To RBC/RRB Intake Manifold Adapter
Great product and KILLER customer service. Adapter bolted up nice and easy.
steve
Discussion Starter #4 (Edited)
Check out the newly reduced pricing on RBC TB Adapters!!!
I was able to source lower manufacturing costs and figured I'd share the savings with my customers!
Now only $60 shipped domestically within the US.
Discussion Starter #5
It has been confirmed! This adapter will work with an 05-06 RSX-S TB!
Just relocate the stock MAP sensor to the actual MAP sensor location used on the RBC, then use the provided rubber plug to block the no longer utilized MAP port on the 05-06 RSX-S throttle body.
Enjoy!
looks good brian!!
look forward into getting one soon hopefully after vacation. :up:
is there way to make the accord tb work with this plate.
since the type S tb is hard to find. :up:
I know the plate can be made but the throttle cable mounting bracket to fabed up??
Discussion Starter #8
bossman032 said:
looks good brian!!
No rush Bossman... I'll have one waiting w/ your name on it!
Thanks,
Brian Karwan
Karcepts, Inc.
Discussion Starter #9
You wouldn't need this adapter to bolt up the Accord TB, as the bolt pattern is the same. There are interference issues that are somewhat of a pain to avoid when the Accord TB is bolted straight onto an RBC, but they could be avoided with a spacer plate if one was made up. I may look into this in the future seeing as though the k24 swaps are seeming more popular nowadays... as of now, there is no easy solution for that...
nice adapter kit!!
gunna get me one of these soon :up:
Are these in stock right now?
If so i'm about to place an order:up:
Discussion Starter #15
I have a few left right now; however, I my inventory will be replenished this upcomming week, so there should be no worries...
Sounds good!
I'll go ahead and place an order for one right now on your site:up:
Discussion Starter #17
JDMboy said:
Sounds good!
No problem, I'll look out for the payment! Your order will ship first thing Monday morning and will take 2-3 business days for you to see it.
Thanks for the support! :up: :up: :up:
payment sent from [email protected] :up:
thanx for you help
quick question..........im assuming that 2 rsx throttle body gaskets will be used before and after the spacer?
thanx again
Discussion Starter #19
thanx for you help
thanx again
I see your payment! Thanks for the purchase!!!
As for the gaskets, page 2 of the Installation Instructions shows the Honda part numbers for the gaskets needed.
16176-RBC-004: 06 Si TB Gasket
16176-PRB-A01: EP3/RSX TB Gasket
Let me know if you may have any further questions.
Thanks,
Brian Karwan
Karcepts, Inc.
Thanx :up:
1 - 20 of 216 Posts
