1 - 20 of 29 Posts
Forgive my noobness, I am new to this level of auto repair but I am trying to learn. I have a 08 accord EXL and decided to open my valve cover recently to do some inspection of the engine as I bought it recently. I checked timing and see if I have the updated VTC actuator (I have startup rattle). Turns out my timing chain tensioner is fucked, with something in it broken. Gonna replace it with a new oem part. Timing is slightly off, cam tdc has crank about half an inch off of tdc.When I was putting it back together, I rushed a little because I needed the car soon and stripped 2 valve cover when trying to torque it down (was tightening each one slightly going around all 6 bolts and didnt realise 2 were spinning).
So my questions are: Can I time the engine by setting cam TDC, taking timing chain off cam, setting crank to TDC, put chain back on cam, place in new tensioner, turning crank a few times to verify timing, readjust if wrong. I realise it likely wouldnt be perfect but would be better than what its like currently? I would also like to avoid taking off the timing cover if I can...
Another question is do i need to take off the cams down to the cylinder head in order to helicoil the threads? I tried looking up someone doing it on this engine and couldnt find basically any information. But it seems like it goes: remove camshaft bolts, take off both the top and bottom camshaft assembly, helicoil threads on cylinder head, reinstall camshaft assembly, then im good?
Let me know if these plans are wrong, again sorry for my noobness.
2004 CM7 Accord - K24A4 - 5 Speed Manual
Are the threads on the top of the post spinning or the ones in the head? I’ve had the first one happen a few times but not the second one. As for timing, I’ve not been able to make any timing adjustments without removing the timing cover, nor would I recommend trying since you may break more things in the process (which I have done).
in order to helicoil you need to remove the cam towers; I can’t in good conscience tell you to do otherwise. Would hate to see you mess anything else up by trying to do it the “easy” way (ask me how I know)
I actually havent checked if its the head or the post thats spinning. Could it be that the post has broken off underneath the valve cover but not in the head? I felt slight resistance when turning it so Id assume it was the head. I decided to not open it up again until I get the parts to replace everything so I can do it all at once. When I remove the cam towers, it seems pretty straight forward. Do I put rtv under the rocker assembly on the opposite side of the vtc?
About the timing, how could it break something? Not trying to challenge you, but is it just like a dont ask just do thing? I just see it as like its only like a half an inch of ccw rotation so like whats the worst that could happen as long as I verify timing a few times?
Thanks for the quick response!
READ READ READ. After you SEARCH SEARCH SEARCH. It's that important. You might be able to run a tap down the threads. As far as "how bad can it be"? Words can not heal those wounds. So I'm gonna take a deep breath for you and do some OHHMS- OHHHMMM OHHMMMM ahhhh. Much better. :cautious:
· Super Moderator
It's almost certainly not stripped in the head. Those bolts are much larger than the little 6 mm threads on the end for the valve cover. Pull the valve cover and replace the bolt with a new one, good as new.
How many miles are on this? You sure the timing chain hasn't stretched causing it to jump time? Might not be a bad tensioner.
Automotive tire Motor vehicle Bicycle part Vehicle brake Rim
Ok, will check the bolts when I open it up next. Not sure about chain stretch, and not really too sure how to check for that other than taking it off… but yes the tensioner is bad I believe. The lever that is supposed to face down is almost vertically up. Added pic for more context
· Super Moderator
This would be a good indicator of chain stretch. I once had a '07 Accord with 280k miles on it (mostly highway). It jumped time and bent valves. The chain had stretched so much over time the tensioner could no longer keep it tight. The stretching was actually causing it to eat through part of the chain case.
If you want a healthy engine you should pull the cover and do a full timing job. If your tensioner is bad you should check the chain AND the guides make sure there’s not a ton of wear. Do it once and have the that piece of mind that you’re not gonna have other issues. You can find cheep kits if it’s a beater and you don’t wanna spend the like 500$ on OEM parts
Discussion Starter · #9 ·
Looked up how to do the job, doesnt seem too bad, think im gonna do it. It just seems pretty time intensive and a bit intimidating cause I've never done something this involved with a car before. Guess theres a first for everything.
Discussion Starter · #10 ·
It has 145k miles on it. Would like the car to last to 200k
Oh, handsome, your hands are too strong. Forgive me if I can't help you
That's not enough to have severe chain stretch in my opinion. Could be a failed tensioner as you mentioned.
What does that have to do with this thread?
You don’t know that I’ve stretched a chain in under 60k miles under extreme driving conditions. Could be either I couldn’t say without looking at the engine. Not a bad idea to check the chain and guides though. If you do condemn the chain and do the job make sure you have an impact or the right tools to get the balancer off. Other than that, timing is easy just make sure it’s at TDC and line up the ticks
· Super Moderator
OEM chain or an aftermarket brand? When I say 145k miles isn't enough for severe stretching, I assume it isn't in extreme conditions. I absolutely could be wrong. I have had a cheap aftermarket chain stretch significantly after just 40k miles, and not in extreme driving conditions.
Yeah that one caught me off guard also? WTF Good advice on the issue as more people are due or have been needing to do this! Bad things can happen when you slack off this. As to the other theres a bit more to it procedure wise than just tdc and line it up. You can be 180 off or even a tooth off easy enough. He's new at this and should be careful to follow procedure.
I stretched a chain car had less than 60k on it bone stock but I was racing it a LOT. It’s a new car to him and we don’t know how the last owner drove it. As stated above if you’ve never done timing definitely watch a few videos and be careful but it’s not too bad just be diligent it’s also easy to do incorrectly.
'03 RSX Type S
This may be anecdotal, but in my experience, the valve lash tends to get tighter over time. Especially the exhaust valves. I always shoot for the middle of spec and err on the loose side. My 2 cents
Too tight and you risk burning exhaust valves, especially over time.
NO? Now is a good time to discuss this. What do you set yours at? Many people agree that they do sinch up over time. I just set mine on a compleatly re done head at .012 in. .016 ex. for startup.
1 - 20 of 29 Posts
