1 - 7 of 7 Posts
k24z3 Accord 2008 - oil filter localisation
I did a search before
As some people knew, an k24z3 has an oil filter located at the bottom of the engine block.
As per this picture :
The usual location of the oil filter is blocked like on this picture :
I wondering if I have to block off the bottom location and install an oil filter as per usual when I do a k24z3 bottom with k20a-r head and accessoiries ?
Re: k24z3 Accord 2008 - oil filter localisation
k24a8 changed for K24z3, I made a mistake, sorry
It's a k24z3
And now I found out this thread :
http://www.k20a.org/forum/showthread.php?p=1537012 post #7
http://www.k20a.org/forum/showthread.php?t=63586&highlight=k24z3
http://www.k20a.org/forum/showthread.php?t=80101&page=3 post#46 and #48
Simple observations
-The Z timing chain cover doesn't match the A Block.
-The Z has what appears to be an oil return hole into the timing chain area.
-The Z Oil filter is located on the lower part of the block versus the normal Honda location.
1 - 7 of 7 Posts
