1 - 3 of 3 Posts
K20A3 swap questions
Ok I have a CRX with everything setup for my k swap. Got the mounts in, the linkage, the axles are ready to swap in as well.
I'm trying to get this thing in and running as in expensively as possible.
I'm planning a K24A4 and a Civic Si 5 speed transmission or just a full EP si swap until I'm done building an N/A Type S motor.
Is it possible to get either swap in and running without a k pro?
If so what is needed?
Re: K20A3 swap questions
You cannot run that motor without KPRO period. There is no ecu that will work with that motor. You might be able to use a PRC ecu but you will be running lean etc the fuel/ignition maps are very different. So in short NO you will need KPRO
1 - 3 of 3 Posts
