1 - 6 of 6 Posts
Just decided to stop with this project because I'm tight on time. I'll have pics up asap, local pick up is prefered in 323 area but I will ship at buyers expense. Rundown on this, is the mains weren't measured out and caused piston slap.
Fresh rebuilt K24A4 head, valve seats and seals are new 300
K24A4 bare block that needs some cylinder wall work on cylinders 1 and 4, will come with OEM headgasket 200
Wiseco 12:5:1 87.5 Pistons/Rings/Locks/wrist Pins with BP H-Beam rods. Have about 10 miles on them and 2 of the pistons are brand new. 850
Pretty much new crank aswell, same about 10 miles on it 250
Used K24 crank, spun a rod bearing, easy fix 100
Type-S Oil Pump set up w/ chains 150
Type-S Oil Cooler setup with water housing/pump 150
RBC Manifold, uncut w/ tb spacer 225
BP Headstud bolts 120
K24A4 oil pan 50
bump how much for the block n shping to nj??? all i really need is the girdle that bottom plate... but ill take the block too so lmk
1 - 6 of 6 Posts
