1 - 5 of 5 Posts
Formerly unix4linux
Hello Members,
Looking to see if someone can tell me what is the pinout of the Oil Pressure Sensor. This is for a 2003 Honda Accord ECU.
I'm in the middle of wiring a digital oil pressure gauge and haven't been able to find the pinout on this board/forum. There are a handful of dead links.
Thanks in advance!
Formerly unix4linux
Discussion Starter · #2 ·
Wow, even the pinout diagrams I've found don't have anything for the oil pressure sensor. I only see info for VTC and VTEC related to oil. Is it labeled something else?
Just to make sure, it's not giving you an oil pressure readout... only a binary switch. On or Off.
The Oil Pressure Switch is for the warning light on the dash. When the oil pressure hits a certain PSI or below, it grounds the switch and the light comes on.
If you're trying to read Oil Pressure, you'll need to add your own wiring.
Formerly unix4linux
Correct, I have a T coming off that sending unit on the block to a pressure sensor for the gauge. I wanted to trace the power, signal and grounds to keep everything close together but good info nonetheless 馃憤
1 - 5 of 5 Posts
