1 - 9 of 9 Posts
i new to the k series. and i was wonder what would be the best thing to do, i have a k24 block and a k20a2 head... im looken to break 500 hp, nd willing to dump 8 grand into this project.. i was looken to supercharge maybe turbo. looked into jakson racing procharger, or the supercharger that runs likea turbo.. also should i just get bluprint everything from hybridracing?
i also herd that a k20 oilpump and oil pan is better to use becuase the k20 oil pump pumps more oil? is this true.
Re: k24a4 bottem k20a2 head. build
Hi, you need to learn alot before doing that build, so read as much as you can here at this forum, and btw here is a some nice threads to start with:
http:/http://k20a.org/forum/showthread.php?t=28668
If youre going for 500hp you need a turbo or a Kraftwerks kit. And for the oilpump its because to get rid og the dual balanceshafts that everyone change to the k20 oilpump.
Good luck on the build!
link no worky??:down:
I would not have hybrid "blue print" anything. They are pretty good at fabricating mounts and swap parts but I truely do not believe that they have the facilities nor the ability properly build a motor.
If you are actually looking to build a motor I would suggest that you look into ERL or if you really want something extreme, then look into Endyne. I am currently looking at having Larry at Endyne build me a custom K20z1 for my turbo setup.
If you want 500whp you are going to have to have a built motor and a good turbo setup. This is a 4banger, a supercharger isn't the best option if you are looking for that kinda power. I suggest a good kit like Peakboost, Full-race or AFI, a simple built k24 frank (piston, rods, blue print & balance), a GT35 turbo and a fist full of cash.
He is referring to the company blueprint not actually having us blueprint his engine and we are more than capable of building his engine (we have 5 in the shop now) and just picked up a DYNO about a month ago for testing.
I had no idea that you guys had upgraded your facilities.
i have a question i have a k24a4 with a k20a2 head , i was wondering if it is a good idea to make it turbo since it is a high compresion frank. and also how much hp can i get out of it by making it turbo and how much psi can the k24a4 block handel.
1 - 9 of 9 Posts
