1 - 20 of 28 Posts
Here is my setup I have been currently working on.
Let me know your thoughts please.
Stock K24a4 Bottom
Brian Crower Stg 2 Boost Cams
Brian Crower Valve springs/Retainers
850cc RC Injectors
CP pistons
BPM I beam rods
P2R Fuel Rail
Walboro 255lph fuel pump
Return Fuel Setup
Cybernation Turbo Mani
Turbonetics t3/t4 50 trim
38mm Turbosmart wastegate
Greddy FMIC and piping
HKS SSQ 2 Bov
Hauman Pro Boost controller
msd 3 bar map sensor
Powerbox Modified EP3 IM
Hondata IMG
Ep3 5 speed transmission
Competition stage 1 clutch
Competition 9lb flywheel
3 inch turbo back exhaust no cat
Hondata kpro
im shooting for around 400whp or so with a good tune.
what do you guys think?
Stock K24a4 Bottom
550cc RC Injectors
P2R Fuel Rail
Return Fuel Setup
HKS SSQ 2 Bov
Hondata IMG
Hondata kpro
We made 350 on your a3. I'm pretty sure we can make 400 on k24a4 bosssss
would your clutch handle the extra power and torque?
Honestly I think I am better off going this route aswell or something similar I would be saving a crap loud of money...I have a K20a-r swap w/ Greddy turbo kit and a K24a2 as a back up...just upgrade my turbo part and im set!! Your making me think!!
You will need minimum 750cc injectors for that setup and a stage 2 clutch.
Yeah you will need atleast 750 injectors
Michael
Discussion Starter #8
A new clutch probably is a must, and if you think i need 750cc injectors then i might as well buy them too so im not disappointed when I get it dyno tuned. It does make sense to do the clutch being that the trans is already out of the car! :rolleyes: What will this be safe to rev to?
if the tranny is out of the car change the clutch now. It only makes sense.
Also, those 550cc injectors are way too small. You need to get at least RC750's
I am looking at pushing mid 400's on my setup now and I have the 750's with a full fuel system but my tuner thinks that I need at least 1000's
Good luck with your build
First thing I thought of when reading his setup. Clutch wont hold and the 550's wont even come close to supporting that hp goal. I think even with the 750's you would be in the mid to high 80's duty cycle.
550's will be About 100% on 400whp... But on 350whp his duty cycle wasn't even in the 60's lol.
But yea, 750's would be nice. And there is already a stay 2 clutch in it tom.
I think RC recommends that the duty cycle on there injectors not go over 92-95%. So make sure you invest in those 750's.
1 - 20 of 28 Posts
