I'm planning to do a K swap in my crx using a K24A2 tsx head on a K24Z3 accord block. I'm going to use tsx pistons and rod in the K24Z3 block. Plus, a K20A2 oil pump, chains, baffle plate, and chain guides.
Looking through some forums, some say there is a hole that need to be blocked off if a K20A2 oil pump is used on a K24Z3 block. Any info on that?
I know that the K24Z3 block has a different crank angle sensor location. Is it still fine to run it there or should I run the crank angle sensor at the pulley side? Is the voltage reading different from the two differently located crank angle sensors?
Also, would a tsx headgasket fit correctly on the K24Z3 block?
And lastly, does a Si or RSX-S transmission bolt up to the K24Z3 block?
Any info on this would be greatly appreciated!! I know not many people run the K24Z3 block, but its the only block that I have... Thanks in advance!!!
