1 - 7 of 7 Posts
· GoldStar
rod bolts: 27 ft lbs + 120 degrees rotation
head bolts: 29 ft lbs + two steps of 90 degrees rotation (another 90 on top of that if the head bolts are new)
cam cap bolts: 8mm bolts (12mm drive): 16 ft lbs, 6mm bolts (10mm drive):8.7 ft lbs
· Arouse the DAMPFHAMMER!
OK so this is my first 8th GEN project where I have an R18,and I am replacing it with a K 24a2
Can the R 18 Dash wire harness work with the k24 a2?
Does the R18 have CAN bus or analog signal sources? Regarding the building time of the R18 engine I would say it's a signal similar to the K24 engine speedometer. Maybe this helps: DIY: a 05+ VSS/Transmission with an 02-04 Harness
Thanks but I am Installing an RSX 6 speed manual trans,installed clutch pedal,changing the Cluster to the si. Full conversion I got the car practically free this is why I’m taking this route
1 - 7 of 7 Posts
