1 - 2 of 2 Posts
I have a k24a2 in a 96 hatch and it starts, idles fine, but the coolant system never really seems to build pressure and over heats. I have the hasport inline temp sensor/fan switch adapter in the upper rad hose, but plan on moving the fan switch to the bottom of the rad seeing as how I'm running an ep3 rad. My assumption is that the water pump is bad? If the thermo were bad it would stay open correct? temp reads in cluster and on kpro.
Also even tho the temp is high the fan plug never gets power to it and the relay works... maybe moving the switch down? :confused::confused::confused:
any help would be awesome bc I'm doing this with support of here and a very occasional friend.
thanks guys
1 - 2 of 2 Posts
