You will need a karcepts adapter. A crv passenger mount (04-05). The rbb manifold will clear the radiator support. Will need kpro to run. Your 5 spd tranny will bolt up.Hi:
I want know what i need to swap k24a2 longblock in my ep3 if some one can help me thanks:up:
I got k24a2 in my ep3..I don't got the karcepts adapter,,stock..& I don't got the crv passenger mount..avid solid mounts..yes rbc manifold++ k-pro u need..5spd tranny bolt up no probYou will need a karcepts adapter. A crv passenger mount (04-05). The rbb manifold will clear the radiator support. Will need kpro to run. Your 5 spd tranny will bolt up.
you have to have some kind of t/b adaptor because the rbb an rbc manis are made for drive by wire t/bI got k24a2 in my ep3..I don't got the karcepts adapter,,stock..& I don't got the crv passenger mount..avid solid mounts..yes rbc manifold++ k-pro u need..5spd tranny bolt up no prob
my manifold came in a box that read "RBB" however it is stamped "RBC" and i dont even know about this karcepts adaptor can i get a linky please?If you run a rbb manifold, you will need a karcepts adapter.
i use a TB adaptor. on my rbcyou have to have some kind of t/b adaptor because the rbb an rbc manis are made for drive by wire t/b
Your tps is most likely hitting the radiator support or it was removed from the tb. In either case, you will have have the parameters tuned, in kpro. Possibly even replace it. You will also have to modify the radiator support so that it doesn't hit anymore.Can anyone help me or lead me in the directon of help? I have a k24a2 in a Ep3 .....I have everything everyone else stated needed..but I"m getting a check engine code P0123 tps high voltage...can I use a stock tps from another ep3 tb or do i use ad diffrent k series tps? Help please.
junkyard, parts for sale section, k20tuned.com....there are alot of places. start doing your research for the swap.Where is a place that I can get the required parts for the swap? and how much will they cost?
But isn't revving at 7500 RPM on a K24 equivalent to a k20 revving at roughly 8500? I thought the stroke was longer on the K24's.RC 440cc injectors [/B]for this swap for sale..
True, the dc5 head may flow a little better. If you get a longblock, not worth swapping heads in my opinion.But isn't revving at 7500 RPM on a K24 equivalent to a k20 revving at roughly 8500? I thought the stroke was longer on the K24's.
