1 - 6 of 6 Posts
I have a 2004 4dr k24a2 swapped civic has the factory hubs does anyone know what cv axles will fit? I already know tsx one's wont
Are you using the super long passenger side axles or do you have the half shaft all the ep3 axles I can find have the full size passenger axles
Are you sure you're looking at EP3 axles? They never came with a single long passenger side axle but instead a intermediate shaft bolted to the back of the block then a similar length CV axle down to the hub.
The regular Civics that generation with the D17 engines used a single long driver side axle.
1 - 6 of 6 Posts
