1 - 3 of 3 Posts
Hey guys, I'm brand new to this. Ive got a K24a2 swapped 2005 EP3. Looking to make around 400-500 whp with a turbo. From what I've seen stock internals should be fine. But I'm not sure where to start on upgrades, exhaust and air intake are the only things I've done. I'm putting the type s oil pump on here soon, but not sure where to go next. Injectors? Intake manifold? Or just slap a turbo on that bitch. Build threads and any advice is appreciated, thank you!
Discussion Starter #2
Also putting a type s water pump on, need to look into which cam gear to swap onto her as well.
Injectors, fuel pump, ecu tuning such as hondata, upgraded clutch. Full turbo kit with manifold, turbo, intercooler and charge piping, all supporting oil lines, exhaust piping. Heat wrap everything near by.
1 - 3 of 3 Posts
