Looks like 2nd gear tops out at 62mph or thereabouts?i have k24 ep3 with a 6 speed but here is a clip of a guy with the same setup as me with a 5 speed tranny
there is a delay /dampener plate on the master cylinder. Just swap out for an em1 civic one or any late model Honda. It is called a ''feedback plate'', but it is just a bitch on your synchronizers and a failure point as well. I have an 06 6spd TSX as wellrandom question guys: i have a 6 speed 04 tsx and im noticing now that it doesnt seem to shift into second right away when it gets up into high rpms.any thoughts on what could be wrong?
You can use either the 5 or 6 speed k20 transhello . I'm trying to find out . I have a k20a2 . Can I swap my tranny to a base model or do I have to keep it 6 speed??
what axles & half shaft are you using?as everyone already said 5-speed transmission bolts up fine.
I'm running my EP3 trans with a K24a2. You feel like you don't need the 6-speed when you drive it for the first week.
Then you're like "shit, I need a 6-speed..."
