This weekend I visited the dyno to do some dyno tunning for the first time by myself. But the results were not completely satisfying, so I thought I have to ask the best Honda forum about opinion and do some Brainstorming.
Setup is as followed:
K24A2, stock block and Head
regrinded OEM cams, lets say similar to DC Drop in Cams with 50°VTC gear
K20A2 double valve springs
K20A2 Oil Pump
RSP Ported Intake Manifold, 74 TB with 89mm Intake
R-Crew Replika Header, 200 Cell Cat, 70mm Exhaust
Tuned for around 12.8 AFR, under VTEC I have 30* VTC, on VTEC at the beginning 40*, at 6k rpm then falling to 30* at the limiter. Around 23-25* Ignition Timing, anything more, there was no gain at all.
Also, I wouldn't mind the 250 HP, but the torque is quite low, 250 Nm. At 4500 its making exacly the same torque as K24 from the factory, ~230Nm. The Torque looks like the typical modded K24 curve, just low numbers.
All the numbers are at the Crank, DIN Norm, it was around 25 °C, engine is healthy.
What do you think, could be low reading dyno, I am expecting too much? Was hoping for around 260 HP and at least 265 Nm.
Let the discussion begin.
K20A2 Oil Pump
