Happily on my way to completing the swap. 07 Acura TSX Motor. Installed a Skunk 2 K20 Manifold, Skunk 2 Alpha Throttle Body with RSX TPS and IAC.
Installing a Mitch Auto Parts full harness. Getting everything buttoned up but have some question on a few vacuum related items, where to route, what to delete. Any help will be greatly appreciated.
Q6. A vacuum line 90 degree with some sort of a coolant sensor at the bottom. No eletrical connection to it. Removed from the right side of the OEM K24 header. What do I do with this?
Q7. Do I need to plumb the hard lines back to anything?
Q8. What is this, and do I need to plumb this anywhere. Has no electrical connection?
Q9. Control Solenoid Valve. Do I need to plumb this somewhere, and where to?
I attached photographs of all these Questions. Any help will be greatly appreciated.
On a side note, I live in zip code 11365. Who would be the best tuner to visit once the swap is all said and done. I more than likely will go with a Honda K-Pro.
