r/s is hype. Have you ever figured out what the actual angles are?
from say a 1.5:1 to a 1.7:1 there is VERY minimal difference in angles. Yes im talking about 3 oclock and 9 oclock. I don't have a scientific calculator with me, but I did calculate several different r/s ratios and was very very surprised at the results. I encourage you to do the same.
Not only that the very notion of "rod to stroke ratio" is flawed. It should be "rod to *crank throw* ratio". Even smokey yunick, the "father" of r/s ratio, laughed when people destroked their engines or went with smaller stroke cranks to improve rod stroke ratio.
Talking about a longer stroke vs shorter stroke engine. It's quite simple, if engine A spins 6000 rpms x amount of piston speed and engine B spins 9000 rpms with the same piston speed, both will make "similar" power. However, we all know that as RPM's increase, the stress in internal parts increases EXPONENTIALLY. Therefore, even given the same piston speed, engine B is much much more stressed. Rev engine A to 9000 rpms? more power to ya, if you want.
piston speed, well, is *kind* of hype. Build the engine around the horsepower and rpms, not the other way around. Any properly designed components should withstand almost any piston speed we can toss at it. The limit of the induction should be reached before this. Parts failure? Something wasn't designed right. There are many more factors in this then we can possibly imagine, piston speed, instant G's, average G's, weight of piston/assembly, compression ratio, peak cylinder pressure, rpms, yadda yadda. To say an engine is going to blow at x piston speed is ridiculous.
