I was just wondering if the all the K24 trannys use the same mounting points like the K20 trannys do, specifically the Element tranny and TSX tranny. Would the TSX tranny be a straight swap into an Element?
No. The Element and CRV have a longer case which allows for the mounting of the 4x4 mechanism. All of the internals are basically the same minus gear ratio changes. You can just buy the gears and shift linkages to make an Element tranny the same ratios and 6 speed as a TSx.
1 - 2 of 2 Posts
